Today I promise that it will be interesting – I start work on the „wagon vice” type clamp. Here is the question to you if anyone knows the Polish name of this clamp? I have to admit that I had slight concerns about this work, but after carefully studying the drawings and printouts it turned out that it would not be so bad. The key of course is the accuracy of fitting all elements. One bad dimension will entail further mistakes etc. I invite you to the 1st episode about this clamp.
The screws used for the platters can be found here: https://goo.gl/yKTiJ4
Lakie Erie plans and videos can be found here: https://www.lakeerietoolworks.com/
Beech wood – https://www.jaf-polska.pl/
Zostaw komentarz
